New Taper Bushings from Econobelt are Designed to Fasten Rotating Components without Marring Shafts
New taper bushings from Econobelt are designed to fasten rotating components without marring shafts. These stainless steel taper bushings, identified as the QTM-BSS Series, are stocked in 18 sizes to fit shafts ranging in diameter from 4 mm (.157") to 20 mm (.787"). Their outer diameters range from 8 mm (.315") to 28 mm (1.102").
At the new Econobelt eStore you can get immediate quotes, download 3D models, and place online orders. Go to: www.econobelt.com/Q460/RFQ/default.asp?Page=Pg_1-251.html Other power transmission solutions provided by Econobelt include over 9,000 off-the-shelf timing belt pulleys, belts, belt and roller chain tensioners and other components for prototypes and production applications.
Complete technical specifications are contained in catalog Q460, which is available to users of power transmission components free upon request from Quality Transmission Components, Division of Designatronics, Inc., 125 Railroad Avenue, Garden City Park, NY 11040-5016. Phone: 516-437-6700 Fax: 516-328-3343.
