New Sharpshooter Fluid Dispensing System for the Hard to Reach Spots
In some automated assembly or machine lubrication applications it is sometimes difficult to get near the point that needs the fluid or lubricant. In some applications, the fluid is extremely expensive and must be dispensed very carefully and precisely. In some applications, a mist of lubricant is not acceptable for the surroundings - either in the air or on the surrounding equipment. And in some applications, moving the dispensing system in and out to the point of lubrication is too expensive. The new Techno-Sommer Sharpshooter lubrication system solves all these problems and more! The system works off standard shop air at up to 90 psi and can place a drop of lubricant at up to 1m away with pinpoint accuracy. A pressurized tank generates internal pressures up to 750 psi. When a pulse is generated, a fixed drop size is dispensed. Up to 8 dispensing nozzles can be attached to one tank. The dispensing nozzles are available in 4 sizes ranging from 5 mm3 to 100 mm3. An extension hose of up to 2 m in length allows for the dispensing nozzle to be placed around corners and in very hard to reach spots. The Sharpshooter will work with most fluids that do not contain solid particles or adhesives with a viscosity range of 10 - 150 centi-Stokes (mm2/sec.) (SAE 75 gear oil to SAE 90 gear oil or cream to tomato juice).
