New Line of Timing Belts and Pulleys from BRECOflex
The ARC Power Plus line of timing belts and pulleys from BRECOflex are available as open-ended, spliced and welded endess and truly endless polyurethane timing belts. According to the company’s press release, advantages include reduced vibration and noise level, increased power, 100% tracking in both running directions without flanges. Additionaly, the company promises smooth interaction with idler and tensioners running on the toothed side of the timing belt eliminating tooth jumping, based on the overlapping tooth arrangement.
