New Fluid for Grinding Applications
The Grindex line of water-miscible synthetic grinding fluids from Blaser Swisslube provide the ideal rinsing and settling behavior for modern grinding operations. It is best suited for steel and irons as Grindex runs at low concentrations. Two versions are available, including the normal Grindex 10 amd the Grindex 10CO. The Grindez 10CO is inhibited for carbide grinding to prevent cobalt leaching. Both versions offer improved corrosion protection, even when used at low concentrations. Grindex fluids are engineered to ensure good washing action and foam protection. Fluids are transparent when mixed in water and suitable for applications using all wheels with any grit.
