New Ball Bearing Inserts from QBC Features Dual Seal
A new series of 35 ball bearing inserts from Quality Bearings & Components - QBC feature dual seals with an antirotation device. These set screw type ball bearing insert bearings are identified as the BBXINS-... Series. They are made to fit shafts ranging from .1/2" to 4" in diameter. The overall diameter of the bearings range from 1.5728" to 7.0866". Quotes plus online orders are available at the new QBC eStore.
QBC has in stock: miniature bearings, plastic bearings, rod end bearings, spherical bearings, pillow blocks, sintered bronze bushings, radial ball bearings, thrust bearings & washers, sleeve bearings, needle bearings, inner races, roller clutches, guide wheels & rail systems, linear ball bearings, inner and outer ring spacers and shafting. QBC stocks both inch and metric sizes. Our eStore allows you to check price and availability, place an order or request a quote anytime. QBC also provides custom-made bearings and shafting to the customer print. We also offer on-site relubing of bearings in a certified class 1000 clean room.
