Neugart Introduces Latest Compact Right-Angle Gearbox
Neugart USA introduces its new compact right-angle, flange-mounted WPLFE gearbox for applications with tight space constraints and powerful torque requirements.
Depending on the frame size, this gearbox requires up to 30 percent less space than comparable right angle gearboxes. With lifetime lubrication and minimal installation height, WPLFE has the flexibility to mount in any direction to help optimize small spaces. This model’s standardized flange interface makes it easy to mount drive components—such as pulleys, belt drives, rack-and-pinion systems, linear units and rotary tables.
In addition, WPLFE’s large flange output shaft diameter provides five times the torsional stiffness of an output shaft with a feather key. WPLFE also comes with deep, low-friction groove ball bearings that produce little heat, ultimately improving the lifetime performance of the gearbox and drive.
