Material Handling Packaging Controllers Linear Motion Motors Servomotors Servos Product News Energy Efficiency
Moticont Offers High Force Linear Servomotor
A high force Linear DC servomotor from Moticont has been added to their expanding line of voice coil or moving coil motors. The LVCM-095-038-01 Linear Voice Coil Motor is a true servo motor featuring zero cogging, high accuracy, and high repeatability when operated in a closed positioning loop. Clean non-commutated, zero cogging, zero backlash voice coil motors (also referred to as linear actuators) are, efficient, brushless high speed linear servo motors. This LVCM-095-038-01 Linear Servo is 3.75 in. (95.3 mm) in diameter and has a continuous force of 23.1 lb. (102.7 N) and a peak force of 73.1 lb. (324.4 N) at a 10 percent duty cycle.
This brushless, energy efficient, smooth motion, compact servomotor just 2.250 in. (57.1 mm) long at mid-stroke, and featuring low inertia, high acceleration/deceleration, and high speed is ideal for:  Workholding and clamping, assembly, positioning, sorting, testing, wafer handling, dynamic vibration absorption, medical devices, industrial and packaging applications.
The motor features a pattern of four 10-32 UNC-2B threaded mounting holes in the housing and in the coil end to easily integrate into new or existing applications.
As with all of Moticont’s linear servomotors, the LVCM-095-038-01 can be ordered as a complete plug-and-play system including an encoder and servo controller.
moticont.com
