Mitutoyo Measuring System Inspects Large and Small Workpieces
Mitutoyo America Corporation announces availability of the innovative, new Ko-ga-me measurement head - designed to bring full capability to applications where a compact, high-performance, 3-D CNC, 2- or 3-axis measurement system would be ideal. Mitutoyo Ko-ga-me measuring systems are available for horizontal or vertical installation and can be used in stand-alone applications or integrated into work cells. Ko-ga-me is suitable for inspection of large or small workpieces and offers a wide range of available measurement probes including touch-trigger, optical or constant contact probing. The Mitutoyo Ko-ga-me is available in 40 mm, 80 mm, and 120 mm stroke models and offers a resolution of 0.02 µm, a measuring accuracy from 1.5 x (3L/1000) µm, a maximum drive speed of 200 mm/s (1 axis) and has a maximum acceleration of 0.4G (1 axis). In addition the unit supports probes including: TP200+PH6, SP25+PH6M and QVP (QuickVision Pro).
