Gear Drives Product News
Mitrpak Gear Drives Meet Indexing Requirements
A full line of right angle gearboxes that are designed for conveying, manufacturing, packaging, and process applications that require precise indexing is available from Mitrpak of Uxbridge, Massachusetts. Mitrpak Right Angle Gear Drives are rated in accordance with AGMA Class 1 service conditions (1.0 service factor) and provide smooth, vibration-free operation with virtually zero backlash. Designed to meet precise indexing requirements, they are offered with single input and single or double output shafts, 1:1 or 2:1 ratios, and 3/8", 1/2", 3/4", 5/8" and 1" output shaft sizes. Featuring hardened alloy steel spiral bevel gears in a robust aluminum alloy housing with stainless steel shaft drives, each secured by locknuts, and bonded lip grease seals to prevent contamination, Mitrpak Right Angle Gear Drives are lubricated for life with Mobilux EP O. They are shipped completely enclosed and sealed and have mounting holes.
