Miki Pulley Couplings are Effective at Dampening System Vibration
Miki Pulley is introducing its unique CPU Pin Type couplings for direct sale to OEM’s in North America. These CPU couplings are highly effective at dampening system vibration.
Designed using a simple but effective pin and bushing connection that minimizes vibration, CPU couplings handle angular misalignment of 4 degrees and parallel misalignment of 0.5 mm. The unique coupling design maintains zero backlash for smooth system operation. Also, the CPU couplings aluminum construction makes for a lightweight yet strong coupling body capable of absorbing and dissipating heat from adjacent sources in a system.
Another important feature of the Miki Pulley CPU coupling is its ease of installation design. Clamp style hubs slip easily onto two connecting shafts with the coupling locked into position with recessed tightening screws.
Handling system speeds up to 4,000 rpm, CPU couplings are RoHS compliant and are ideal for packaging systems and similar applications. They are available in three models in bore sizes ranging from 6.00 mm to 22 mm. Transmittable torque for these sizes range from 2.2 Nm to 25 Nm.
In addition to the CPU coupling line, Miki Pulley designs and manufacturers a complete line of motion control components. These include flexible shaft couplings, shaft hub locking devices, clutches, brakes and speed control devices.
