Microsecond Heat Treatment of Gears
The performance of metal surfaces can be dramatically enhanced by the thermal process of rapid surface melting and re-solidification (RMRS). When the surface of a metal part (for instance, a gear) is melted and re-solidified in less than one thousandth of a second, the resulting changes in the material can lead to: Increased wear and corrosion resistance, Improved surface finish and appearance, Enhanced surface uniformity and purity, and Sealing of surface cracks and pores.
