Mayr Power Transmission Will Be at sps 2026
At the sps 2026 in Nuremberg, mayr power transmission will present highly integrated solutions that create space for smooth processes. Safety brakes such as the ROBA topstop series are used for this purpose. The matching ROBA brake-checker module enables sensorless brake monitoring. Combined with the ROBA gateway, the system delivers valuable data for proactive machine maintenance, a digital twin and smart production environments.
The drive specialist from the Allgäu region will also present hollow shaft brakes for applications with high torque and a large space requirement inside the application.
The ROBA topstop is equipped with a standardized plug for easy connection and integration into sensorless monitoring systems.
The ROBA topstop from mayr power transmission holds the loads in position reliably and prevents uncontrolled movements in case of power outages or emergency stops. As they are placed between the motor and the output, the brakes can be retrofitted in existing constructions — a solution that reduces effort and costs.
For everyday industrial use, the ROBA topstop brake system is designed as an independent, compact module. O-rings at the interfaces ensure reliable sealing against dust and moisture. The brakes achieve IP66 protection as standard. The vertical axes remain secured even when the drive is dismantled, which is advantageous during maintenance and transport. Thanks to the adaptable flange dimensions, the system can be easily integrated into existing constructions.
