Marposs Offers Grinding Gauge for Immediate Machine Compensation
Marposs Corp. has announced the availability of its new P3dME electronic gauge amplifier for post-process monitoring of smooth and grooved parts. This device, in conjunction with Marposs measuring heads, is a flexible, practical, and reliable solution for checking parts immediately after they have been machined. The P3dME will measure the workpiece and provide immediate compensation information to the machine tool. This ensures that parts are within tolerance limits and helps to optimize cycle-times.
The P3dME is a compact gauge that can be installed on the machine tool as a standalone device or integrated into the machine front end PC using a dedicated HMI.  It features a 7-inch touchscreen with an intuitive, easy-to-use operator interface. Its robust housing is designed to withstand harsh shop-floor environments and resist abrasive grit, metallic particles, and cutting fluids.
The unit is available with either two or four channels for connecting to Marposs LVDT or HBT type measuring heads. Depending upon the chosen measuring head, the P3dME has a measuring range of ±250 to 2000 μm.
