Marksman Diagnostic Tool Converts Ultrasonic into Audible Sound
Tracer Products has introduced the Tracerline Marksman ultrasonic diagnostic tool, a highly accurate instrument that converts and amplifies inaudible ultrasonic sound into audible "natural" sound. Now, service technicians can easily hear sounds that signify problems such as air brake leaks, gear and bearing wear, as well as vacuum, EVAP system, exhaust refrigerant and passenger compartment leaks. The Marksman uses a two-tiered process to ensure accurate diagnosis. First, the receiver unit converts inaudible sound into audible sound using a process known as heterodyning. Then, the receiver's Sound Signal Technology fine-tunes the audible sound into the natural sound emitted by the defect itself. A 10-bar LED display indicates the intensity of incoming signals from the problem source to ensure error-free diagnosis.
The Marksman Master Kit comes with a receiver, full-sized headphones, two anodized probes and an ultrasonic emitter that allows technicians to test for faulty seals, gaskets and weather stripping in passenger compartments, trailer bodies and other unpressurized enclosures. When attached to the receiver, the 12-inch hollow probe accentuates air sounds, while the solid contact probe accentuates sounds of wear or grinding inside gears. Standard nine-volt batteries are included for both the receiver and the emitter. All components are packed in a sturdy storage case with foam insert.
