Linear Roller Block and Rail Systems Now Available From LM76
Low cost, SAIBO SB-LGB Linear Roller Block and Rail Systems are now available from LM76 in three sizes to meet load requirements up to 1200 N. (270 pounds).
These narrow profile linear motion systems feature low noise, smooth travel, high speed to 10 m/s (120 ft/s), high acceleration to 50 meters per second, low weight, high linear accuracy, sealed radial low friction bearings and low cost. Due to their narrow profile they are easy to install into new and existing applications.
SAIBO SB-LGB Linear Roller Block and Rail Systems have an adjustable preload system to control the required level of precision needed for most applications. The roller block has six drilled and tapped holes for mounting tooling, cameras, test equipment and more. They can be used in robotics, assembly, pick-and-place, sorting, packaging, manufacturing, sampling, laser cutting, wafer handling and other precision applications. The rail systems are protected from debris, dust, chips, and contaminates by plastic end caps with spring loaded oil filled felt pads. The felt wiper pads also deliver lubrication to the guide and rollers. The wipers are easily relubricated through convenient oil ports in the end caps.
