Kyzen to Exhibit Metalnox Alkaline Cleaners with Corrosion Inhibitors at FABTECH 2022
Kyzen, the global leader in innovative environmentally friendly cleaning chemistries, will exhibit at FABTECH 2022, scheduled to take place November 8–10 at the Georgia World Congress Center in Atlanta. The Kyzen Clean team will highlight Metalnox M6314CP and Metalnox M6324CP in Booth #B5017.
Cleaning and then protecting metal parts is traditionally done in two stages with two different chemistries; however, there are products with the corrosion inhibitor built-in to simplify the process while providing pristine parts. Visit Kyzen at FABTECH to learn how its product offerings for clean, rust-free parts can save both time and money.
Metalnox M6314CP is an aluminum-safe alkaline parts cleaner formulated to remove numerous manufacturing oils used in a range of machining, stamping, and deep draw operations. M6314CP is built with effective steel corrosion inhibitors to provide long-term protection for both mild and cast steel. With its advanced formula, this product successfully prevents flash rusting common in the aqueous processing of ferrous metals. Metalnox M6314CP also is suitable for use on non-ferrous metals, stainless steel, chrome steel, aluminum, magnesium, and HSS-parts.
Also on display, Metalnox M6324CP is formulated to remove chlorinated, paraffinic oils used in various machining, stamping, and deep draw operations. It is built with effective steel corrosion inhibitors to provide long-term protection from rust. M6324CP can be added to both the wash and rinse stages of multi-stage cleaning systems and is excellent at removing difficult soils including carbon smut and chlorinated oils. Low foaming with a very low VOC, M6324CP is easy to use and environmentally friendly. The solution provides effective steel corrosion protection for up to 90-days of indoor protection and has an oil-splitting formula to allow efficient oil removal.
