Kluber Lubrication Introduces Specialty Grease for Wet and Aggressive Environments
Klϋber Lubrication, a worldwide manufacturer of specialty lubricants, introduces HYDROKAPILLA NBU 20 HFE US, designed for the lubrication of plain and rolling bearings, and chains. It is designed for applications that experience high humidity and/or aggressive media. The grease can be used in drive and carrying chains for wet amusement park rides, carrying chains for textile steamers and any chains subject to aggressive environments (hot water, chlorinated water, steam, alkaline and acidic solutions). HYDROKAPILLA NBU 20 HFE US, with its excellent penetration into pin and bushings, resists corrosion and prevents chain seizure. It can be applied manually, via brush or an automatic spraying system.
