Klingelnberg Offers Latest Metrology Solutions
For decades, users in a broad array of industries have relied on Klingelnberg’s proven measuring technology, which replaces up to six conventional measuring devices. The result is fully automatic execution in a single clamping of gear measurement, optical measurement, general coordinate measurement, form and positional measurement, roughness measurement and contour measurement. The measuring technology and machine design are the same for the entire P-series line of precision measuring centers and can be customized with add-on options. In the G series version, Klingelnberg Precision Measuring Centers are perfectly suited to production processes that require not just dimensional measurement tasks, but particularly complex form and surface measurements in large numbers.
P 16 G – Solutions for complete measurements of roller bearings
Roller bearings have to perform several different tasks at once: they have to ensure high stability for shafts while providing low power losses and high durability. The resulting requirements concerning material, geometry, form accuracy and surface roughness represent a particular challenge for manufacturing, as current quality standards require the use of a number of different precision measuring devices. Dimensions are therefore measured on a coordinate measuring machine, form and noise emission on a form tester, surface roughness on a surface tester and contours (e.g. edge radius) on a contour measuring station.
P 26 – Cut measuring time with Klingelnberg Optical Metrology
To be equipped for all measurement tasks, Klingelnberg combines HISPEED OPTOSCAN optical measuring technology with the established, high-precision 3D NANOSCAN probing system. This system incorporates maximum precision with the required robustness for a production environment. Thanks to the high-speed changeover feature, the optimal measurement system can be used for every task.
P 100 – Innovative measurement solutions for large components
Whether making gearings for rail transport, the wind power industry, printing machines or the mining industry – the fully automatic CNC-controlled P 100 precision measuring center is the perfect fit. Highly precise, reliable and compact, and available with the whole range of software and hardware options, this precision measuring center ensures that all universal requirements will be met, even for job shoppers. Long workpieces can easily be clamped between centers and reliably measured thanks to a long vertical axis measuring up to 1200 mm. The high-precision rotary table allows the P 100 to be used as a full-fledged form measurement device. In addition to precise, thermo-homogeneous mechanical parts, an integrated vibration isolation system, temperature-neutral measurement systems, workpiece temperature logging and a sophisticated temperature model in the machine ensure highly precise measurements – in or out of the measuring rooms.
P 40 – Proven solutions in gear measurement
Stringent precision requirements for gearing measurements and increasingly complex drive components demand the best measuring technology available and a machine and software concept optimized for these applications. That's why leading manufacturers put their trust in Klingelnberg precision measuring centers, which represent the most widely used standard in the industry, while also serving as the reference for metrology institutes. Simple, easy operation of the measuring centers is guaranteed for all applications, as will be demonstrated at the booth using the P 40 precision measuring center as an example. Not only does the entire model range stand out for its premium machine quality, but reliable quality assurance is also ensured throughout.
Please contact Klingelnberg directly to discuss the company's services and software solutions.
