Kapp Niles ZX Series Offers Machine Flexibility
The Kapp Niles ZX series provides high-end productivity, even for bigger gears and larger modules. It is driven by an electrical high-accuracy direct drive, providing a high level of positioning accuracy even for the profile grinding process. The compact design enables all operations from the shop floor and allows for easy set-up for machining individual parts, low and medium serial production volumes. The changeover between profile and generating grinding processes only lasts a few minutes. The tool spindle has a counter support for better rigidity and optimal surface finish. A wide range of dressing processes is available, e.g. double flank dressing with simultaneous tip dressing, single flank dressing and more.
