J.W. Winco Offers Steel Control Levers
JW Winco, Inc., A Ganter Company, a leading supplier of standard industrial machine components, announced it has available GN 223 Steel Control Levers with Round Through Bore, with or without Keyway and Square Through Bore versions.
These RoHS compliant control levers, offered standard in metric sizes, feature a steel hub and arm with a black oxide finish, while the ball knob is black phenolic plastic with a glossy finish. Inch size Bores, Keyways, and Set Screw Holes are available upon request.
The GN 223 Steel Control Levers perform smoothly and powerfully thanks to the heavy-duty arm of the lever.
