Joral Rotary Encoder Offers Rectangular Design for Easy Mounting
PE18 ProxEncoder non-contact rotary encoder product line receives a square housing with side sense capacity.  Enhancing the original PE18 proximity style form factor, the new rectangular design allows for easy mounting on flat surfaces. Two USPTO patents enable the PE18-BX ProxEncoder to detect on-axis rotation with up to 0.5” (12 mm) air gap between the application and sensor.  The PE18-BX is 100 percent encapsulated for an IP69k configuration that survives destructive conditions like submersion in hydraulic oil, deep sea salt water, dust control spray, or corrosive wash. The PE18 ProxEncoder product line is designed to cater to both mobile hydraulic and industrial installations. It is available in common communications including analog, quadrature, and CAN J1939.
