ITW Rocol's Lubricant Applied to Grinding Wheels to Increase Belt Life
Accu-Lube Stick lubricant is a ready-to-use lubricant stick that is applied to the tool before start-up.
Accu-Lube Stick can be used on grinding wheels to allow them to cut freely and improve wheel life.
The lubricant stick is designed to give better finishes and increased belt life for belt grinding application. Additionally, it can also be used on saw blades. The system reduces heat build-up in belt, disc or wheel grinding operations and is safe for all metals including aluminum.
Accu-Lube Stick does not need to be diluted with any other material and is safe for all types of metals. This blue solid stick is a neutral product that does not cause contamination or discoloration of products. It is biodegradable, non-toxic and naturally consumed in the process so the need for clean-up and disposal is eliminated.
