Intellidrives Offers ServoBelt Rotary Stage
ServoBelt Rotary Stage from Intellidrives offers an economical solution for a variety of light and medium-duty rotary motion applications. It features a very large clear aperture of 350 mm and provides arc-second resolution when driven from a micro-stepping or brush-less servomotor controller.
The low profile design is made possible by the use of compact precision bearing. The rotating carriage of the stage provides unlimited motorized rotation angle of the load up to 100 kg and has large clear aperture to allow the passage of the optical path or cables directly through the stage.
The main body of the stage is made from lightweight anodized aluminum and can attach directly to an optical table or moving linear or XY actuators and can be mounted at any orientation. The ServoBelt stage uses a belt drive to achieve high rotating speed. Its lightweight design makes it easy to incorporate this rotary stage into high dynamics XY-Theta multi-axes systems.
