Intellidrives Expands XY Table Series
The XY-BSMA-WJ series precision XY tables from Intellidrives are low-profile stages designed for a wide range of applications. This is highest precision XY stage option for applications that require low-cost stepper motors and brush-less servo motors
The XY-BSMA-WJ series uses stiff crossed roller mechanical bearings for support and smooth motion. Precision pre-loaded ball screws allow higher speeds and better accuracy compared to lead screw driven motion products. Servo motors and linear encoders can be added for more precise positioning and accurate feedback for the high repeatability and accuracy.
These highly repeatable XY tables are ideal for use in high-performance applications in industrial robots, fiber optics and photonics, vision systems, machine tools, assembly, semiconductor equipment, medical component laser machining, micro-machining, electronic manufacturing and other industrial automation applications.
