Innovative Design Solves AutomotiveParts Assembly Challenge
Innovative Design Solves Automotive Parts Assembly Challenge
This automated assembly machine produced by
Alpha Integration, required an innovative design
and custom approach from supplier Weiss North
America.Weiss North America, Inc. of Willoughby, OH has designed and produced rotary tables and other components for the automation industry for more than 45 years. When approached by Alpha Integration, Inc. of Murfreesboro, TN, a manufacturer of turnkey automated assembly, vision and testing systems, to provide a reliable turnkey solution for their 6-foot-tall automotive parts assembly machine, Weiss ‘tiered-up’ an innovative chassis and indexing table system solution.
In the process of laying out the plan of the machine, Alpha’s senior mechanical design engineer, Sam Westbrooks, knew he wanted an open-center indexer to mount the tooling towards the inside of the dial system on a stationary center plate. This design configuration would accommodate ease-of-loading for its 12 load stations, as well as providing clear viewing of the processes and easier maintenance.
Additionally, to facilitate the tooling, the indexer would have to be 5 feet off the ground, which would require the base frame/chassis to be uniquely structured.
Tiered-Up/Open-Center Technology: The key to the Weiss solution involved the stationary center plate, dial plate, and base frames. These were all manufactured and machined complete by Weiss at their Willoughby, OH facility and delivered to the client as a one-source, preassembled system. This allowed Alpha to build the nest and station assemblies offline so that they could be integrated to the dial system with ease.
At the core of the fully integrated system was the Weiss TR1500 rotary index table ring with a large open center— which offered an extremely low profile design with a high level of accuracy. The TR1500 ring allowed for optimal design space in a robust mechanical design. This also reduced the overall footprint of the machine with improved accuracy and access to parts. Even with Alpha’s machine featuring 12 clip install stations, it proved no problem for the Weiss TR1500 series, which offers ring diameters of up to 2,200 mm — providing more than enough scope for coupling with processing stations.
The height limitations of the chassis design were overcome by utilizing one base frame that leveraged two other riser frames to make up the rest of the height. The first riser attached to the top of the base frame and supported the TR1500 index table that featured a 90.5" diameter tool plate. The second riser frame was used to suppport the electroless-nickel plated steel stationary plate. Ultimately, the frame/riser system design was able to lift the index table up to the specified height requirements, with the final system structure resembling a ‘three-tiered cake’.
Because there is no tooling in the way, the
dial system is wide open for ease of loading
and allows for an easier view of the entire
production process.
The system accommodates a wide variety of weights and loads while maintaining
accuracy and long life.
To accommodate the downward forces
generated by the assembly machine’s press
stations, the Weiss design uses an intermediate
riser weldment going through the indexer and
bolting to the middle riser frame.
