Ingersoll Introduces NanoFeed Technology
Ingersoll’s New NanoFeed technology provides exceptional hi-feed milling performance for machining of miniature components & smaller part features. NanoFeed is a 20° hi-feed indexable insert design that will replace smaller diameter solid carbide end mills in many applications and offer great economy. Inserts have been designed with pressed-in coolant channels, directing coolant or air directly to the cutting edge for maximizing tool life. Inserts also have backdraft side clearance for straight-wall milling capability. Available in diameters of 6 mm and 8 mm with steel or carbide shank options, NanoFeed will reduce cycle times, increase productivity and help to reduce solid carbide usage.
