Presentation of the Model
Figure 2 Shafts definition.
The model is a 6AT gearbox concept with power variation on the input. Different load spectra are defined in the KISSsys interface that is used to perform all the calculations, but only the maximum load condition, representing the most critical case, is used for the optimization below. This spectrum is defined (Table 1) with a requested lifetime of 2 hours for each shifting gear.
1
14.555
242.74
—3393.3
2
9.0935
5000
406.51
—3539.8
3
5.6958
5000
450
—2473.4
4
4.2188
5000
450
—1849.5
5
2.9464
4881
450
—1299.5
6
2.229
3905
450
—978.28
R
—9.155
3000
229.75
2020.5
When calculating the strength for each shifting gear independently, we can see that the most critical one is the second — mostly because in this configuration the highest torque is applied on the output shaft. Concerning the reliability of the system for each gear shift, we then get the results in Table 2, which is consistent with our previous observation.
1
2.9308
4.2191
5.603
100
2
1.4903
2.074
5.9691
99.121
3
4.0445
5.6288
13.909
100
4
2.5326
3.824
11.236
100
5
7.4115
11.191
32.882
100
6
22.25
33.596
98.716
100
R
3.4608
3.5567
3.924
100
In the current state of the gearbox, the bearings are the most critical elements decreasing system reliability. Because of the axial loads, bearing types, and model size, we don't have a wide range of optimization for these specific elements.
Concerning the casing consideration, we can neglect its effect on the bearing positions — especially in the automotive industry, where these elements are normally very stiff.
With these inputs defined, we can identify the following most influential criteria to manipulate for gearbox optimization:
- For weight: shafts geometry, gears width
- For noise: shafts geometry, bearings and loads positions, gears tooth profiles
- For efficiency: gears tooth profiles
From this list we can easily estimate a good optimization process:
- First, modify the shafts geometry and gears width to reduce the weight of the gearbox while running the strength analysis to keep safeties and lifetimes above required values.
- Then, while reducing the mass, maintain a stiff design for the dynamics analysis, pushing the Eigen frequencies of the system as much as possible above the meshing frequencies.
- Finally, optimize the gears tooth profiles for a reduced transmission error and improved efficiency while considering the shafts deflections and misalignments.
It is also important to mention that the materials of the different elements, which could also be optimized, were not modified in this study.
Shafts and Gears Mass Reduction
To avoid dimensioning the coaxial group of shafts, we calculate its maximum transmittable torque in its current state. Thanks to the basic formula of the torsional stress, we can then get a corresponding mean diameter that we can compare to the current one. This method allows us to estimate the potential mass reduction of the system by applying the opposite logic and considering the current torque as the maximum transmittable one. This approach is of course just a rough estimation that consists mostly in scaling down the complete shafts with gears and bearings.
We then calculate the transmittable torque of the coaxial group (s1-s6), shafts and gears, for the second gear shift, and get a maximum of around 500 Nm, instead of the current 406.51 Nm, without decreasing its reliability below 99%. At this point we just have to size some bearings because of low lifetimes for this torque. For this torque difference of 23%, the torsional stress formula gives us an equivalent mean diameter difference of around 7% for the coaxial group of shafts.
At first, and to compare our results afterwards, we also apply this method to the idler and output shafts to estimate the total mass reduction of the system. We calculate their own transmittable torque, so without verifying the connecting gears, and get the following results:
- For s7: 2,400 Nm instead of 1,450.96 Nm — thus a variation of around 18% in diameter.
- For s8: 6,000 Nm instead of 3,539.8 Nm — thus a variation of around 19% in diameter.
For the real optimization and the rest of the study, we in fact only consider the virtual input torque of 500 Nm to resize the two parallel shafts and connecting gears, while keeping their reliability above 99%. Here we modify the shafts geometry and gear widths only to avoid creating some interference by modifying the center distances. As the gear safeties are above required values for the coaxial group, we also slightly optimize their width. We can then apply the scaling down of 7% to the whole system on top of these results to achieve the potential mass reduction for the input torque of 406.51 Nm (Table 3).
s1-s6
19.26
17.88
19.14
17.78
s7
5.8
4.74
4.86
4.52
s8
10.74
8.67
8.51
7.9
Total
35.8
31.29
32.51
30.19
Figure 3 Mass reduction comparison for s8 (left) and s7 (right).
We then get around 15% off total mass reduction; and when comparing the optimized and theoretic masses for s7 and s8, we can see that we are quite close to the initial estimation.
Dynamic Analysis of the System
A first evaluation of vibrations in the system requires performing a modal analysis. This allows us to identify the Eigen frequencies of the shafts and their mode shapes. We can then compare these values with the potential excitations coming from the meshing frequencies. For this analysis is quasi static, the results should theoretically be the same for all shifting gear. But as we consider the gyroscopic effect to get closer to reality, the Eigen frequencies are different for each operating speed. The same applies to the operating torques since the bearings stiffness calculated from their inner geometry is nonlinear. The study is then made for all shifting gear, but as similar results can be observed, we can summarize the analysis with the second gear again.
We compare the modal analysis of the shafts before and after mass reduction, and can interpret the results quite well on shaft s7. First, we calculate the meshing frequencies of the system (Table 4). Here we don't calculate the harmonics and modulated frequencies with the shafts speeds, as we can already identify some critical frequencies (around 1,300 Hz, and around 1,700 Hz) in the analysis of Table 5.
1242.1
632.33
1026.1
1786.9
571.95
1
1316.38 Hz
Axial
1219.51 Hz
Bending XY
2
1651.90 Hz
Bending XY
1394.17 Hz
Axial
3
2842.85 Hz
Bending YZ
2381.32 Hz
Bending YZ, Bending XY
4
3785.94 Hz
Bending YZ
3108.07 Hz
5
4064.81 Hz
Bending YZ
3132.68 Hz
Bending XY
6
16169.46 Hz
Bending XY
15329.62 Hz
Torsion
7
16649.82 Hz
Bending YZ
16137.30 Hz
Bending XY, Bending YZ
8
17928.96 Hz
Torsion
16444.57 Hz
Bending XY
9
18220.94 Hz
Bending XY
19378.30 Hz
Bending XY
We can see that the meshing frequency of around 1,700 Hz is no longer critical to the optimized shaft; but the one around 1,300 Hz — more important due to its coming from the excitation of the gear directly mounted on the shaft — is still present and now close to two different mode shapes, i.e. — axial and bending. We can also see that, in general, the Eigen frequencies of the optimized shaft are lower than the initial one for torsion and bending mode shapes. In general, it then seems that the stiffness of the shaft is reduced for these, but slightly increased for the axial deformation.
We can confirm this interpretation by decreasing only the length of the initial design — without changing the diameters — and comparing its modal analysis with the one from the initial shaft (Table 6).
1
1316.38 Hz
Axial
1211.70 Hz
Bending XY
2
1651.90 Hz
Bending XY
1385.86 Hz
Axial
3
2842.85 Hz
Bending YZ
2375.54 Hz
Bending YZ,
Bending XY
4
3785.94 Hz
Bending YZ
3090.85 Hz
Bending YZ
5
4064.81 Hz
Bending YZ
3115.11 Hz
Bending XY
6
16169.46 Hz
Bending XY
18508.19 Hz
7
16649.82 Hz
Bending YZ
18762.10 Hz
Torsion
8
17928.96 Hz
Torsion
18762.16 Hz
Torsion
9
18220.94 Hz
Bending XY
18775.73 Hz
Bending XY
First, we can see that when reducing the shaft length without changing the diameters we manage to push the first torsion mode shape in higher frequencies, thus making the shaft stiffer for this deformation. Concerning the bending mode shapes, we cannot see much difference below 4,000 Hz, simply because the nodes of these modes are mostly located at the position of the right bearing where no change was made for the diameter between all designs.
To get another estimation of the different mode shapes evolution, we compare the distance between loads and bearings when the shaft length and diameters are kept constant, like the virtual shaft displayed in Figure 4. We can clearly see that the shaft gets stiffer against torsion when the loads are close to each other in Table 7, as we can see a very steep part in the torsion mode shape between the two spaced loads as a difference from the close ones (Fig. 4).
1
1264.80 Hz
Bending XY
1264.82 Hz
Axial
2
1313.09 Hz
Axial
1324.87 Hz
Bending XY,
Bending YZ
3
2269.41 Hz
2266.30 Hz
Bending YZ,
Bending XY
4
3056.80 Hz
3014.84 Hz
Bending XY,
Bending YZ
5
3259.84 Hz
3296.86 Hz
Bending YZ,
Bending XY
6
6805.40 Hz
Torsion
10500.37 Hz
Bending XY,
Bending YZ
7
6938.92 Hz
11025.08 Hz
Bending YZ,
Bending XY
8
7269.97 Hz
13017.89 Hz
Torsion
9
15257.43 Hz
Bending XY, Axial
19157.14 Hz
Bending XY
Figure 4 Influence of loads positions, example of torsion mode shape.
Concerning the axial and bending mode shapes, if we look at these results, as well as the ones from the initial shaft where the loads were close and one load was also spaced from a bearing, we can see that spaced loads and bearings seem to be favorable to stiffness against bending, whereas the opposite appears to be favorable to stiffness against axial deformation.
In a general way, we can then say that a more compact design is better to avoid noise generation. But when reducing the mass, the engineer must maintain a stiff design by keeping correct diameters, avoiding mass concentration, and correcting loads positions depending on the mode shapes he wants to attenuate. In this case, the potential excitation emanates from the meshing frequencies.
Gear Sizing for Noise and Efficiency
For the final step of optimization we perform a contact analysis of the different meshes to evaluate and optimize their peak-to-peak transmission error (PPTE), other influential criteria for noise, and power losses. Once again we perform this analysis on the second gear shift with the maximum load provided.
Figure 5 Carrier mesh s2.
For each gear meshing, we first recalculate the root and flank safeties, considering the shaft deflections, and the tilting of the planet axis from the finite element tool included in the simulation software KISSsoft. We can then observe that with the face load factors (KHb) consideration (Table 8), these safeties are much lower than the theoretical ones calculated in the first step of this optimization.
1.4381
1.1972
1.3241/1.2374
1.0220/1.0736
1.0910/1.2567
1.2775
1.1076
1.2849/1.1926
1.0185/1.0641
1.0891/1.1975
0.1606
0.0896
0.0392/0.0448
0.0035/0.0095
0.0019/0.0592
2.7733
1.3466
0.210
0.036
0.040
2.5181
0.5793
0.342
0.089
0.135
0.2552
0.7673
—0.132
—0.053
—0.095
99.27
97.98
98.90
97.68
99.02
99.39
99.11
99.19
98.67
99.45
0.12
1.13
0.3
1
0.45
We try then to optimize the gears macro- and microgeometries in terms of transmission error (sizing of the profile modifications as well for a smooth meshing during the same operation) and power losses, considering the face load factors calculations due to the shafts deformations, and for a reliability of the system still above 99%. The center distances and gear widths are kept constant, as well as the gear ratios (with a minimized deviation).
During the sizing functionality, for better wear reduction we then also choose to consider only the solutions that provide a specific sliding below an absolute value of 3, and profile shifts coefficients optimized for a balanced specific sliding along the path of contact between the pinion and the wheel.
As can be seen in Figure 6, the software covers more than 200 solutions for each meshing, from which we can pick the optimum one between transmission error, efficiency and mass. In this example the solution 200 in the top left corner seems to be the best choice in terms of TE and efficiency, and is in the lower range in terms of mass, which doesn't vary so much anyway from the lightest to the heaviest solution. We perform this operation for the 2 gear pairs and the 3 planetary gear sets; and because an improvement of both efficiency and transmission error is not possible in most cases, we therefore tend to accentuate efficiency when the transmission error is quite low; but that is again depending on the direction the engineer wants to take.
Figure 6 Fine sizing of the gears.
We can generally observe in the optimum solutions that the geometries all tend to provide a transverse and overlap contact ratio getting close to 1.5 each. For example, if the overlap ratio is higher, then the helix angle will decrease, and vice versa. For the rest of the parameters, mostly, modules and teeth numbers vary in opposite directions to maintain constant center distances while getting a transverse contact ratio closer to 1.5. And, the pressure angles tend to increase when the bending safeties are much lower than the required ones.
We can then calculate a total efficiency improvement from around 93% on the initial system, to 96% on the optimized one, when considering only the gear meshing losses. Concerning the transmission error, we can see that the PPTE value is considerably improved for the 2 gear pairs, but slightly bigger for the three planetary stages where the initial value was already very low. Overall, we can say that the optimization for noise reduction on the gears is also successful.
Conclusion
When trying to optimize a gearbox, a considerable amount of solutions exist. If, for a certain system reliability, the perfect solution could be found for noise reduction, it would necessarily be to the detriment of mass and efficiency, and vice versa. Once the objectives of the project have been clarified, an engineer can then prioritize the elements to optimize and find the right balance between the modification of the shafts geometry, bearings and loads positions, and gear tooth profiles. With the help of a designated simulation software like KISSsoft, the engineer can then evaluate the dynamic behavior of several geometric variants of a reducer in a very short time, size the corresponding bearings to match the required lifetime, but also evaluate the relation between transmission error, efficiency, mass or other, of hundreds of propositions of gear geometries with optimized profile modifications that match his design limitations.
Daniel Kupka, M.Sc. studied mechanical engineering (2007—2012) at Ruhr-UniversitÃ≤t Bochum, Germany, including in 2011 the study of automotive engineering, Chalmers TH, Göteborg, Sweden. From 2013 to present (2018), Kupka has worked as a research associate at the chair of industrial and automotive drivetrains, Ruhr-UniversitÃ≤t Bochum.
Dipl. Ing. Thomas Panéro studied mechanical engineering (2007—2012) at INSA Lyon (FR). From 2011—2012 he worked as a design and calculation engineer for the Renault Group (FR) and, since 2014, has worked as a development and support engineer for KISSsoft AG (CH).
Prof. Dr.-Ing. Peter Tenberge, M.Sc.
This paper was first presented at the International VDI Conference on Gears 2017, Garching/Munich [VDI-Berichte 2294, 2017, VDI Verlag GmbH] and is reprinted here with VDI approval.
