IMTS 2016: German Machine Tools of America (GMTA) (N-6924)
Rasoma Machining Centers
Now available from German Machine Tools of America (GMTA), a full line of Rasoma machining centers, including vertical turning centers, 4-axis shaft turning centers, end machining, double spindle and various special purpose machining centers with full automation is offered.
Rasoma machining centers offer high rigidity, due to separate X and Z slides plus the machine head is designed as a monoblock with polymer concrete fill. Thermal stability is enhanced by cooled motor spindles and the rapid traverse on these centers ranges up to 60m/min at high acceleration, with feed and removal speeds up to 120 m/min, less than six seconds from part to part and turret indexing typically under one second.
Full option packages include robotic handling and part articulation, integrated metrology onboard, working inside or outside the work envelope, full tool measurement and monitoring systems and driven tool packages, all controlled by a single Siemens CNC.
Samag Machining Centers
Now available from German Machine Tools of America (GMTA), a full line of Samag machining centers, including multi-spindle, horizontal machining centers, deep hole drilling machines and combination milling/drilling machines, is offered for the North American market.
