Heller HF 5500 5-Axis Horizontal Machining Center Features a Counter Bearing Combined with a YRT
Heller recently introduced the new model HF 5500 5-axis horizontal machining center equipped with pallet changer and offering a work envelope of 900x950x900 mm and a maximum pallet load of 750kg.
With the fifth axis provided by the workpiece for dynamic 5-sided and simultaneous 5-axis machining and Heller's typical horizontal spindle ensuring quick tool changes and short idle times, the HF series offers substantial productivity advantages. In addition, three linear axes in X, Y and Z are equipped with absolute measuring systems and two direct driven dynamic rotary axes in A and B integrated into a swivel rotary table.
The high speed of the A and B rotary axes is achieved through minimized mass moment of inertia and the use of direct drives. Optionally, the powerful dynamics can be increased further with the "Speed-Dynamics Package." According to Heller, it provides 10 percent shorter chip-to-chip times. For an additional reduction in idle times, the HF series provides a high-speed NC tool changer with lift-and-swivel principle.
Contrary to comparable machines on the market, Heller has equipped the new series with a counter bearing as a unique selling point. The use of the counter bearing in combination with a YRT bearing results in high rigidity for handling high loads.
High flexibility was another priority for Heller in the development of the machine: the machine is either available in table design or equipped with pallet changer. The HF also provides a wide choice of spindles to suit different applications.
While the standard version is equipped with the powerful SC63 SpeedCutting motor spindle with HSK-A63 (18,000 rpm, 100 Nm), making it ideal for the machining of light metals, the optional PC63 PowerCutting spindle unit (12,000 rpm, 201 Nm) provides the necessary torque for high-performance cutting of cast iron and steel.
