Haydon Kerk Offers Customized Nut Designs for Motion Control Applications
Haydon Kerk Motion Solutions, a unit of AMETEK/Precision Motion Control, offers customized nut designs for high-end motion control applications.  Precision molded and machined custom nuts create exceptional value for an OEM.  Engineers aren’t required to source a standard “off the shelf” lead screw nut that “almost” meets application requirements.  Haydon Kerk works closely with customers to develop a part especially suited for the mechanism being designed.
Precision nuts made from polymers can be molded in just about any shape or with any complex feature imaginable.  The standard material used in Kerk polymer-based nuts is self-lubricating polyacetal, which offers dimensional stability, good tensile strength, and is easy to machine.  Kerk polyacetal nuts are impregnated with TFE (tetrafluoroethylene) for a permanent, self-lubricating thread contact surface.
Along with self-lubricating polyacetal, Haydon Kerk Motion Solutions offers a variety of Kerkite composite polymers.  Kerkite polymers are a family of high-performance materials that provide exceptional wear properties with the cost and design advantages afforded through injection molding.  Kerkite polymers offer a variety of mechanical, thermal, and electrical properties and are compatible with various chemicals and many harsh environmental conditions.
In addition to Kerkite engineered polymers, Haydon Kerk also produces precision nuts from many alternative plastics, including PEEK (polyetheretherketone), polyester, Torlon PAI (polyamide-imides), Vespel polyimide-based resin, PVDF (polyvinylidene fluoride), Ertalyte PET-P (polyethylene terephthalate), and customer-supplied specialty materials.  Haydon Kerk also machines precision nuts from bronze, brass, and stainless steel.
Thread diameter for custom nut designs ranges from 2 mm (5/64-in) up to 24 mm (15/16-in).  Thread leads are available from as small as 0.30 mm (0.012-in) in the smallest diameter (2 mm) nut up to a coarse 76.2 mm (3.000-in) in the largest diameter (24 mm) nut.
