Hardinge Releases Collet Adaptation Chucks
Hardinge HCAC Collet Adaptation Chucks will adapt most spindles to accept C-series pull back collets, J-series pull back collets, stationary B-series collets, style-S master collets, step chucks & closers and dead-length collets. It is possible to increase your machining capabilities by substituting a collet chuck over a jaw chuck for part diameters up to 6 inch depending on the spindle size.
The benefits of using collet chucks in place of jaw chucks include:
• Lighter weight, no hoist required to mount on spindle
• Faster job setup time
• Faster acceleration and deceleration due to less weight and smaller diameter
• Higher spindle speeds for reduced cycle times
• Optimum gripping with higher precision capability
• Capable of using master collets and pads
• Improved part concentricity over jaw chucks
• Eliminate time spent on boring jaws
• No hazard of jaws flying off
Another style of Hardinge collet adapter is their quick-change FlexC Vulcanized Collet System that provides collet changeover in seconds using a manual compression wrench. The FlexC collet system has a guaranteed accuracy within .0004" (.010 mm) TIR for both collet system styles A (pull-back stationary stop) and D (pull-back thru-hole) and .0008" (.020 mm) TIR for style DL (push-to-close dead-length).The collet head has a generous gripping range to allow variation in bar stock without having to change the collet.Because there is no collet body, the collet segments will remain parallel to the stock even when there are variations in the bar stock. This parallel clamping minimizes stock "push back" that could create inconsistent part lengths. The spindle mount will fit on A2-5, A2-6, A2-8 and some flat back spindles (main and sub).
