Hansford Sensors Launches Cable and Connector Sets
Hansford Sensors has launched two new cable and connector sets for use with its existing range of vibration sensors. The new HS-AC334 and HS-AC335 cable assemblies have been developed for use in applications where IP67 sealing is required, or where vibration sensors have to be used in extreme operating temperatures.
The new cable assemblies are rated for use between -80 and +200 degrees Celsius and are manufactured from FEB (Fluorinated ethylene propylene). This is flexible, robust and provides excellent dielectric strength, making it ideal for a wide range of industrial and process duties.
The HS-AC334 and 335 can be supplied with straight or right-angle two-pin MS connectors, or with three-pin connectors for use with dual output sensors, and are available in a variety of standard or custom built lengths. The new cables are designed for use with most of Hansford Sensors’ industrial accelerometers, including the AC, 4-20mA and dual output vibration and temperature sensors.
