Hainbuch Expands Maxxos Family of Mandrels with T-212
Hainbuch has expanded its Maxxos family of mandrels with the Maxxos T-212, a next-generation ID clamping solution engineered around a powerful idea: geometry creates rigidity.
At the center of the Maxxos design is a hexagonal pyramid clamping interface that replaces the traditional round mandrel connection between the mandrel body and the segmented clamping bushing. Instead of relying on friction alone, the hexagonal geometry creates a positive mechanical fit that dramatically increases torque transmission and resistance to vibration.
The result is a mandrel that holds parts with exceptional stability, even during aggressive machining operations.
Compared to conventional round mandrels, the Maxxos system delivers greater transmissible torque and higher rigidity. This added stability allows shops to increase feed rates, take heavier cuts, and maintain consistent part quality while extending tool life.
The hexagonal pyramid design distributes forces across six contact surfaces rather than relying on a single round interface. This creates a highly rigid connection between the clamping bushing and the mandrel body, reducing micro-movement and improving damping during machining.
In practical terms, the Maxxos T-212 behaves less like a traditional mandrel and more like a structural extension of the spindle, giving manufacturers the confidence to push machining parameters further while maintaining process reliability.
