Gear Drives Industry News
Groschopp Introduces Motor Search Tool
Many search tools in the electric motor industry only allow users to choose search parameters from a drop-down menu. The problem with this method is that drop-down menus limit search combinations, making it difficult and time consuming to find a motor that fits exact specifications. Groschopp’s new motor search tool utilizes a grid layout so users can quickly switch through or add to a variety of parameters. The tool edits the results as the user continually enters search parameters. This allows you to efficiently alter your motor and gearmotor combinations without needing to re-enter the search data for each adjustment. The left portion of the tool provides basic search options: motor type, gearbox style, voltage and phase. You can choose to narrow down a category to an individual search option or leave it open if requirements are less specific. Each basic search selection you make adjusts the maximum and minimum range available for the speed, torque and power of the chosen selection. After determining your initial search parameters, move to the right side of the search tool for the slider bar function. Choose a variable to manually adjust speed, torque or power, and the remaining variables will automatically move to their corresponding ranges. This function assists in making sure your search will produce the best results. Additionally, the company has a new web design, updated site navigation capabilities, 3D models and prints, videos, blogs, whitepapers and other educationbal resources. For more information, visit the website below.
