Gearboxes Offer Range of Drive Requirements
A line of totally sealed, precision right angle gearboxes that feature robust construction and are maintenance-free for a wide range of drive requirements is available from MITRPAK of Uxbridge, Massachusetts. MITRPAK Right Angle Gear Drives feature high-precision, hardened alloy steel spiral bevel gears in a robust aluminum alloy housing with stainless steel shaft drives and positive lip grease seals to prevent contamination. Incorporating locknuts to secure each drive, they provide smooth, vibration-free operation with nearly zero backlash and are available with single input and single or double output shafts and 1:1 or 2:1 ratios.
Permanently lubricated for life with Mobilux EP O, shipped completely enclosed and sealed, MITRPAK Right Angle Gear Drives are rated in accordance with AGMA Class 1 service conditions in industrial applications (1.0 service factor). Units for food processing are available with construction and lubricants which meet FDA regulation section 121.2553 and carry the USDA "AA" rating. Output shaft sizes offered are 3/8", 1/2", 5/8", 3/4", and 1".
