Industry News Product News
Forest City Gear Adds Finish Grinding Capacity
Forest City Gear has expanded its capacity for very high precision finish grinding of external, internal, straight and helical gears and special profiles with the addition of its second Kapp VUS 55P Form Grinding Machine.
The new Kapp Form Grinder gives Forest City Gear the ability to rough and finish grind internal gears with an ID grinding diameter as small as 1.250", and external gears with an OD grinding diameter as large as 19.685".  Additionally, the new machine is equipped with a high speed, 35,000 rpm external grinding spindle, so it can use smaller diameter grinding wheels to more productively grind gears positioned close to shoulders where an interference condition might exist for larger wheels.
In addition, the new machine is equipped with a specific wheel dressing unit, enabling Forest City Gear to run dressable Ceramic and VitCBN grinding wheels for both internal and external gears to meet all types of profile requirements.  The combination of on-board dressing and optional on-board measuring systems both speeds and automates the entire grinding process.
“While our first Kapp VUS 55P continues to be a dependable grinding workhorse, this new model gives us more versatility to meet the requirements of our increasingly diverse mix of high precision projects,” says Forest City Gear Grinding Lead Person Kevin Chatfield. “With quality and delivery standards higher than ever across all the industries we serve, this machine is a great addition.”
