Festo Semi-Rotary Drive Designed for Long Life and Fast Installation
Festo has introduced a new pneumatic semi-rotary vane drive and matched contactless position sensor that transforms a relatively simple and low cost drive into a solution that lowers engineering and inventory overhead, is fast and easy to install, and delivers long service life due to its sealed housing.
Standard swivel angles for the DRVS semi-rotary drive are 90, 180, and 270 degrees. Custom swivel angles are possible with a stop bracket accessory. At six bar pressure, the seven different sizes in the DRVS line deliver a torque range of .15 Nm to 20 Nm. Festo sizing software makes ordering the optimum unit for the application fast and accurate. The company guarantees overnight shipping for standard DRVS drives, which lowers inventory requirements for OEMs and assures end use customers fast delivery of replacement parts.
The SRBS, a compact, contactless magnetic position sensor, attaches to the DRVS via a single cable and three screws. During installation, personnel simply move the vane to the drive’s two positions and with a few clicks of the SRBS push button both positions are located for the position sensing unit. Repetition accuracy is < .0039 inches (.1 mm). Through its push button, the SRBS position sensor can be designated PNP or NPN and NO or NC, which means that one part number covers all the different combinations.
“Festo is fundamentally reshaping its product lines to engineer end-to-end productivity for customers,” said Mike Guelker, Festo product manager. “Customers are going to like the fast, accurate ordering, delivery, and installation of the DRVS and the flexibility, ease of use, and accuracy of the SRBS.”
