Faulhaber Offers Drive Selection Tool
Determine the Faulhaber drive system required for projects with the user-friendly Faulhaber Drive Selection Tool, an ideal solution for developers and application engineers.
Only little information, such as speed and torque, is sufficient in order to quickly determine the appropriate solution. An easy-to-read list with the most important parameters shows the choices calculated. This can then be reduced further using an intelligent filter until the most suitable drive solutions are found. For this, there is a comparison function for up to three variants, whereby the comprehensive product data is immediately presented in a table.
If a certain motor series or special series of a motor/gearhead combination are already relevant, this can be selected in advance and the solution calculated accordingly in connection with the required performance. It is also worth pointing out that the Faulhaber Drive Selection Tool also takes the changes to the electrical characteristics caused by the heating of the motor into consideration with the thermal ("warm") calculation.
This tool is being developed gradually - with additional drive types, products and functions. In the future, users will therefore be in a position to determine suitable drive systems for planned applications at early stages of development.
