Fairloc Shafts & Shaft Reducers/Extenders
The patented system offers several advantages including: built-in overload protection, full use of the bore, easy adjustment, compact self- contained design. With this FairlocĀ® system, the shaft remains smooth. It is self-contained, so there is no additional inventory to keep in stock. The component can be easily adjusted and is fully supported. Two slots are machined into the hub, one oriented radially, the other angularly, this creates a transverse wedge which remains attached to the solid portion of the hub on one side. The resultant cantilevered clamping section has a tapped hole to accept a cap screw which is passed through a clearance hole in the solid portion of the hub, and into a threaded hole in the transverse wedge section. As the screw is tightened, the cantilevered section clamps the shaft securely. The screw can be tightened and released repeatedly without marring the shaft or affecting its torque transmitting abilities. The 3,405 products in this catalog include inch and metric FairlocĀ®: hubs, spur gears, timing belt pulleys, couplings, shaft extenders, shaft collars, and dials. Featured in the catalog are timing belt pulleys which are shown in 6 pitches from .080" through 5.08 mm. The hub gears in the catalog represent the largest single product type and are shown in 120", 96", 80", 72", 64", 48", 32", and 24" Diametral Pitches and in Modules 0.5, 0.8, and 1. All products are available from off-the-shelf stock for immediate shipment.
