Aaron Fagan
Feature Articles
Essential Exhibitors at TPS 2025
A curated list of companies showcasing advanced solutions in rotating equipment
TPS offers a dual focus: a peer-reviewed technical program and a world-class exhibition. The technical program is selected by advisory committees of industry experts and led by respected practitioners. It features short courses, lectures, tutorials, case studies, and discussion groups covering reliability, maintenance, troubleshooting, and emerging technologies. All proceedings are made freely available online six months after the event.
The exhibit hall spans approximately 216,000 square feet and features more than 300 companies showcasing the latest in turbomachinery and pump systems—including gears, bearings, couplings, seals, drives, and full-scale equipment. With over 4,500 attendees from more than 50 countries, TPS offers valuable opportunities to explore new technology, connect with solution providers, and gain practical insights for improving system performance.
For engineers focused on the performance, efficiency, and reliability of rotating equipment, TPS provides direct access to the people and products driving innovation in the field. I hope you find this curated list of exhibitors useful—and I look forward to seeing you there. Be sure to stop by AGMA’s booth (1751) as you make the rounds!
tps.tamu.edu
Recommended Floor Visits for 2025
ABB (Booth 2617)
Motors, variable speed drives, integrated power transmission solutions.
AGMA – American Gear Manufacturers Association (Booth 1751)
Gear standards, education, technical resources.
Artec Machine Systems (Booth 1836)
Custom gear drives, high-speed gearboxes, overhaul services.
Atlas Copco Gas & Process (Booth 1736)
Turbocompressors, expanders, gas processing systems, sealing and transmission tech.
Bently Nevada (Booth 1912)
Condition monitoring, rotating equipment protection.
Cerobear GmbH (Booth 2242)
Advanced ceramic bearings and components for high-speed, high-precision applications.
Coupling Corporation of America (Booth 1625)
High-performance flexible couplings, vibration damping, torque accuracy.
EagleBurgmann Industries LP (Booth 2323)
Mechanical seals, gaskets, bearing isolators.
Elliott Group (Booth 1937)
Turbomachinery, compression systems, drive components.
F. W. Gartner & Curtiss-Wright (Booth 1309)
Thermal spray coatings, surface durability enhancement.
Flowserve Corporation (Booth 2127)
Pumps, mechanical seals, flow control solutions.
Goodrich Industrial Couplings (Booth 2037)
Gear and disc couplings, high-torque applications.
Greene Tweed (Booth 1406)
Sealing solutions, composite bearings, high-temp applications.
Honeywell | CCC (Booth 1821)
Control systems, automated protection for rotating assets.
Ingersoll Rand (Booth 2429)
Air compressors, motion-control components.
John Crane (Booth 1722)
Mechanical seals, bearing isolators, lubrication management.
Kaydon Ring & Seal (Booth 1744)
Custom bearing solutions, precision rings, engineered seals.
Kingsbury, Inc. (Booth 2437)
Hydrodynamic tilting pad and journal bearings for turbines and compressors.
Lone Star Turbo (Booth 2511)
Turbine internals, retrofit components, seals and bearings.
Miba Industrial Bearings/TCE (Booth 2611)
High-performance industrial bearings and power transmission components.
Petroleum Products & Solutions (Booth 2827)
Specialty lubricants and fluids to extend gear and bearing life.
Phoenix Laser Solutions (Booth 2350)
Laser welding, cladding, and gear repair services.
Regal Rexnord (Booth 2229)
Bearings, gear drives, couplings, motor controls.
RENK Group (Booth 2637)
High-performance gear units, slide bearings, industrial couplings.
Schunk Carbon Technology LLC (Booth 1622)
Carbon-graphite bearing materials and mechanical seals.
Siemens Energy (Booth 2329)
Motors, gearboxes, couplings, digital diagnostics.
SKF Magnetic Mechatronics
(Booth 1742)
Magnetic bearings, mechatronic systems, high-speed rotating equipment.
Sundyne, LLC (Booth 2421)
Gear-driven pumps, compressors, engineered rotating equipment.
Thordon Bearings Inc. (Booth 1205)
Polymer bearing solutions with corrosion resistance and long life.
Waukesha Bearings (Booth 1442)
Hydrodynamic bearings and systems for turbines, compressors, gearboxes.
This article appeared in the August 2025 issue.
