Encapsulated Power Supplies Added to Rhino Line
Automation Direct has extended its Rhino line to include AC/DC switch mode power supplies encapsulated in a compact, low profile housing. The PSE series is appropriate for space-limited applications and can be screw mounted to a panel or equipment chassis. The power supplies can also be DIN rail mounted using the optional DIN rail mounting kit.
The PSE series features a universal AC input range of 85-254 volts and is available in single or dual output models. Output voltage ranges include 5, 12, 15 and 24 VDC; and +/-12 and +/-15 VDC. Single output models provide a maximum output power range from 15 watts up to 60 watts. Dual output models provide 15 watts and 30 watts. No external grounding is required since the series is designed with a double-insulated plastic resin housing. Screw terminal blocks provide simple connection, and the series is short circuit and overload protected.
The Rhino PSE series encapsulated power supplies are RoHS compliant, UL and cUL listed. Prices start at $49.50 for single output models and $51.75 for dual outputs.
