EMCO Maier Introduces Hyperturn 65 Powermill
The Hyperturn 65 Powermill offers a large spindle clearance of 1300 mm, a powerful counter spindle which also allows 4‑axis machining, a B‑axis with a direct drive for complex 5-axis simultaneous milling operations, and an additional Y‑axis for the lower turret, making it ideal for machining complex parts.
The ergonomically-designed machine is suited to the serial production of workpieces, for example in the automotive industry, the fields of mechanical engineering and materials handling, but also for the aircraft industry.
Costly turning, drilling, milling and gear cutting operations can be competed in one setup. Additional handling and part storage is eliminated and workpiece precision is improved. Total production time, fixture and personnel costs, as well as floor space requirements can be reduced with the Hyperturn.
With 29 kW and 250 Nm the counter spindle has enough power to machine the workpiece simultaneously with two tools, enabling 4-axis machining.
The milling spindle, with 29 kW, 79 Nm torque and speeds to 12,000 rpm, promotes productivity in the complete machining of complex workpieces. The B‑axis direct drive gives the Hyperturn 65 PM good dynamics and contour capabilities with 5‑axis simultaneous machining, along with shorter tool change times. The additional Y-axis on the lower turret makes milling work possible at the same time as machining with the milling spindle.
The milling spindle with HSK‑T63 tool interface can be used for both turning and drilling/milling work. It can be continuously swiveled within a range of +/‑ 120° and clamped at any point. With a Y‑travel of +120/‑100 mm, even the most complex of machining work can be carried out. This includes gear-cutting operations, turning/milling work for crankpins, 5‑axis machining, and much more. The tools can be prepared according to the customer's requirements with a 20‑piece pick‑up magazine, or a 40 or 80‑piece chain magazine.
