Double Studded Silicone Gel Vibration Mounts From AAC Feature Superior Damping Performance
The mounts, identified as the V10Z61MTH and V10Z61MMN Series, are designed for light to medium loads of from 2 kgf to 3.5 kgf (4.4 lb. to 7.7 lb.) up to 8.5 kgf to 12.5 kgf (18.7 lb. to 27.6 lb.) per mount. Their highest damping effect arises when the gel is compressed 10% up to 30%. An important feature of these metric mounts is their ability to operate effectively over a very wide temperature range of from -40 degrees C to +2,000 C (-40 F to 3920 F). They offer excellent chemical resistance and are low in compression set. Performance remains the same even after repeated use. They contain nothing harmful and are therefore considered environment-friendly. Recommended frequencies range from 14 Hz to 23 Hz. Quotes, online orders and 3-D models are available at AAC's eStore.
Additional specifications are contained in “UNILOAD Constant Natural Frequency Mounts, V105” which is available free upon request from Advanced Antivibration Components - AAC, 2101 Jericho Turnpike, Box 5416, New Hyde Park, New York 11042-5416. Phone: 516-328-3662 FAX: 516-328-3365. The entire catalog is viewable and downloadable in both .PDF and .HTML formats at: www.vibrationmounts.com
