Napoleon Engineering Services specializes in Custom Bearing Manufacturing, Bearing Inspection and Bearing Testing. NES is AS9100C Certified and is your one stop stop for custom bearing product.
Nichiei excels at molding highly functional, precision gears, as small as 2mm, and as precise as .15 module & AGMA Grade 11-12. We also specialize in metal/plastic insert molded gears, as well as precision bearing shafts and retainers, and offer capabilities for small, medium and high volume applications. Plastic gears and bearing components offer many advantages over metal, including lightweight, low noise, low friction (without additives or coatings), corrosion resistance and lower cost. Nichiei has developed this precision injection molding capability over a 30 year period, and has learned that the key to our success is offering a fully integrated solution, from material recommendation, to mold flow analysis, to mold design and manufacture, to prototyping and production, and then to final part inspection. This high level of integration insures we can meet and exceed our customers' expectations.
NSK is a global manufacturer of bearings and other motion & control products. It operates 51 manufacturing facilities worldwide and 12 global technology centers of excellence that draw from world-leading industry knowledge and manufacturing experience. NSK's dedication to engineering innovation results in state-of-the-art products designed to improve performance and extend service life. NSK's unique Asset Improvement Program helps customers improve productivity and efficiency to significantly reduce operating costs. The company's industry and process-specific expertise and solutions are applied to identify and solve problems that are limiting productivity. This enables customers to achieve improved performance, enhanced competitiveness and increased profitability.
