» Gears
Gears are toothed wheels that provide for the transfer of rotary motion from one shaft to another (or rotary-to-linear motion in the case of racks), as well as speed increase or reduction from one shaft to another.
Companies in Gears
Bevel Gears India Pvt. Ltd.
Bharat Gears Ltd.
Bierens Machinefabrieken B.V.
Bonfiglioli Riduttori S.p.A.
Bosch Rexroth
Boston Gear
Brad Foote Gear Works, Inc
Brelie Gear Co
Brewer Machine & Gear Co.
Buffalo Gear, Inc.
Butler Gear
C-B Gear & Machine, Inc.
C&U Americas, LLC
Capstan Atlantic
Carnes-Miller Gear Co., Inc.
Cattini & Figlio s.r.l.
CCTY Bearing
Central Gear & Machine
7
8
9
14
15
