Digital Servo Drives feature PCB mount design
Servo2Go.com has added PCB mounts to its broad range of digital servo drives from Advanced Motion Controls. The DZ drives are micron-sized servo drives require less space than a standard business card and weigh about the same as two golf balls. Designed to be completely compact, DZ's take up little space and eliminate wiring hassle.
Providing 10-80 Vdc operation while delivering 12 amps continuous/20 amps peak current, DZ Series can be configured to operate in torque, velocity and position modes for brushed, voice coil or brushless motors. Units deliver up to 1 kW continuous power when needed and can achieve up to 98 percent efficiency. Supporting CANopen and RS-232/485 up to ~1 Mbaud, drives accept variety of input commands including PVT, ±10 V analog, encoder following, step and direction, and PWM and direction.
More information on the DZ Series micron-sized PCB mount servo drives from Servo2Go.com can be viewed at www.servo2go.com/search.php?search=DZ&D=PROD
