Design Applications Automation Ask the Expert Case Studies Engineering Showcase Basics Gear Design
Determining Diametral Pitch, Center Distance
I need help determining the diametral pitch needed to achieve the closest center-to-center distance for 2 spur gears. The 1st gear is a 34-tooth and the 2nd gear is a 28-tooth. The center-to-center distance between the gears needs to be as close to 2 1/8" as possible.
This article appeared in the October 2016 issue.
