Technical Articles
December 4, 2026
Dr.-Ing. Markus Rüngeler
Dr.-Ing. Philipp Kauffmann
Preetham Jonnalagadda M.Sc.
Technical Articles
Design of Low-Noise Powder-Metal Gears: From Mesh Excitation to System Response
Figure 1—Gear, tire-road, and aerodynamic noise over the speed range of a battery-electric vehicle. Schematic only; curves do not represent absolute sound-pressure levels (Refs. 16, 17).
In battery-electric vehicles, the absence of combustion-engine masking noise increases the perceptibility of tonal transmission noise and exposes sources that are less prominent in conventional vehicles (Ref. 16). Gear-mesh-related components are particularly relevant at low and moderate vehicle speeds, where aerodynamic noise remains limited and tire-road noise does not necessarily dominate the overall sound field. As speed increases, the relative contributions of tire-road and aerodynamic noise rise, while the dominant interior-noise paths remain vehicle- and operating-condition dependent (Refs. 16, 17). As Figure 1 schematically illustrates, the main opportunity to reduce perceived gear whine lies in the operating range where gear noise remains acoustically exposed.
This article presents a design methodology for low-noise powder-metal intermediate gears in electric drive units, in which material properties, tooth microgeometry, and gear-body architecture are developed together as a single NVH concept.
Powder Metallurgy as an Enabler of Integrated NVH Design
Against this acoustic background, gear design must address both mesh excitation and the structural transmission mechanisms that lead to radiated sound. Powder metallurgy offers a particularly suitable platform for this task. Its inherent material damping can reduce selected resonance amplitudes, while its near-net-shape capability permits functional features to be integrated into the gear body with limited additional machining. Experimental and numerical investigations of alternative gear materials likewise show that material selection affects excitation and dynamic response and should therefore be linked to geometry-specific NVH optimization (Ref. 11). The resulting opportunity is not limited to replacing wrought steel with a powder-metal material. Instead, a low-noise solution can be built around the PM process by coordinating material properties, tooth-contact design, and structural architecture for the specified transmission system and duty cycle.
Figure 2 summarizes the NVH value chain from gear-mesh excitation to radiated sound and highlights the three principal design levers considered in this work. Loaded transmission error generates dynamic mesh forces that propagate through the gear body, shaft, bearings and housing, where interaction with structural modes can amplify the vibration before it is radiated as sound. Within this chain, microgeometry controls the excitation, gear-body architecture tailors the structural response and transmission path, and PM material damping influences the dissipation of vibrational energy. This framework illustrates why these effects should be considered jointly when developing a low-noise PM gear solution.
Excitation—Response Framework
Loaded transmission error is a principal source of gear-whine excitation. It is defined as the deviation of the actual relative motion of a loaded gear pair from ideal conjugate motion. The resulting waveform is governed by tooth and gear-body deformation, time-varying load sharing, tooth microgeometry, manufacturing deviations, and system misalignment. Loaded tooth-contact analyses that include measured profile deviations and mesh-stiffness effects provide suitable methods for quantifying these excitation mechanisms (Refs. 6, 9).
This article appeared in the December 2026 issue.
The resulting dynamic forces propagate along a structure-borne transmission path comprising the gear body, shaft, bearings and transmission housing. Each component contributes frequency-dependent stiffness, inertia, damping and coupling characteristics. Resonant amplification occurs when gear-mesh orders intersect structural natural frequencies of components within this structure-borne transmission path. The amplified vibration is transmitted to the housing, whose vibrating surfaces ultimately radiate sound. Gear NVH should therefore be analyzed as a coupled excitation-transmission-radiation problem, as also reflected in system-level e-drive studies combining structural and microgeometry optimization (Refs. 1, 5).
The speed-dependent gear-mesh excitation provides the link between transmission error and the structural response of the drivetrain. The fundamental mesh frequency is defined by the rotational speed and number of teeth, fe = z·n/60, while higher harmonics arise from the periodic mesh-stiffness variation. As illustrated in Figure 3, these excitation orders increase linearly with speed and intersect the approximately speed-independent natural frequencies of the transmission housing, the intermediate-shaft bending mode, and the first-stage gear modes. At an order crossing, the corresponding structural mode can amplify the transmitted excitation and produce a local increase in sound pressure. The acoustic response therefore depends not only on the magnitude of transmission error but also on modal participation, damping and the location of the crossing relative to the operating-speed range. This Campbell-diagram interpretation provides the basis for evaluating how PM-related changes in mass, stiffness, and damping shift natural frequencies and modify resonance amplitudes.
Figure 2—NVH value chain from gear-mesh excitation to radiated sound, showing the three PM design levers.
Figure 3—Campbell diagram of gear-mesh orders crossing natural frequencies of the housing, intermediate shaft, and first-stage gear.
Influence of Material Properties on Structural Dynamics
Residual porosity influences the effective elastic, inertial, and dissipative properties of sintered steels and can therefore be used as part of the NVH design concept. Compared with a wrought-steel reference of identical geometry, the transition to PM generally reduces component mass and effective elastic stiffness while increasing material damping through porosity-related internal friction. The lower stiffness changes loaded tooth compliance, time-varying mesh stiffness, load sharing, and consequently the amplitude and spectral content of gear-mesh excitation. The damping benefit and the excitation change therefore occur simultaneously and cannot be represented by a damping factor alone. Figure 4 summarizes the three material-property changes most relevant to the transition from wrought steel to PM: reduced mass, lower effective Young’s modulus, and increased material damping.
Reviews and dedicated measurements of sintered materials substantiate the dependence of Young’s modulus, damping, and other physical properties on total porosity and pore morphology (Refs. 4, 8). For sintered Astaloy 85Mo, tensile, compression, and hardness measurements further show that density, pore shape, and sintering conditions substantially affect Young’s modulus, yield strength, ultimate tensile strength, ductility, and the difference between tensile and compressive behavior; models based only on spherical pores do not reproduce the measured response with sufficient accuracy (Ref. 15).
In a gear application, these property changes influence both the tooth-contact problem and the modal response of the complete gear-shaft assembly. High-density single-compaction technologies and secondary cold- or hot-forming processes can increase density and improve durability to the level required for high-performance gear applications, with the objective of meeting relevant wrought-steel benchmarks (Refs. 12–14). Prior work on highly loaded PM gears further identifies damping, lightweight design, stiffness-based geometry design, and manufacturing-related properties as interdependent elements of an integrated transmission solution (Ref. 14). The resulting properties depend on alloy composition, heat treatment, pore morphology, local densification and the manufacturing route. These parameters should therefore be characterized and incorporated explicitly into the design model so that the acoustic potential of the PM material can be used systematically.
The modal effect of a powder-metal gear depends on the spatial distribution of stiffness, mass and damping. For a bending mode dominated by the gear body, reduced effective stiffness tends to lower the modal frequency, whereas reduced mass tends to increase it; the resulting frequency shift depends on the mode shape and on whether the gear body, shaft, or their coupling dominates the stored strain and kinetic energy. Increased damping can reduce resonance amplitude without necessarily moving the resonance. Shaft-dominated modes may respond differently because shaft stiffness remains approximately constant while the attached gear mass and body stiffness change. This mode-specific behavior provides a design space that can be exploited through coordinated material selection and body geometry. Mode shapes, modal participation factors, damping ratios and gear-shaft assembly frequencies should therefore be evaluated together. The measured benefit is expected to vary with torque direction, torque level, rotational speed, and the proximity of mesh orders to structural modes. Available system tests showed favorable PM behavior at selected partial-load drive conditions, but less favorable behavior under coast and in a high-speed region; the performance gap decreased with increasing torque. This pattern is consistent with simultaneous changes in loaded contact, mesh excitation, and resonance amplification rather than with a speed-independent material effect. The objective is to use the PM-specific property combination to reduce critical responses and move relevant resonances away from highly utilized operating regions.
Figure 4—Effect of PM density on component mass, effective Young’s modulus, and material damping (Refs. 4, 8, 15).
Microgeometry Adaptation to Loaded Contact Conditions
The lower effective elastic modulus of PM changes loaded tooth deformation and load sharing relative to a wrought-steel gear. Consequently, flank corrections optimized for the steel reference cannot be transferred to the PM gear without verification. Profile relief, crowning, and lead corrections must be adapted to the PM-specific compliance, including the system-level deflections of shafts and bearings and the relevant drive, coast and torque conditions. The optimization must jointly consider loaded transmission error, contact pressure, tooth-root stress, manufacturing deviations and tolerance sensitivity (Ref. 10). The objective of the PM-specific microgeometry is to reduce mesh excitation to a level comparable to that of a conventionally manufactured gear with optimized microgeometry. Only when the excitation levels are comparable can a subsequent reduction in system response be attributed primarily to the higher material damping of PM.
Optimization should include representative torque levels and both drive and coast conditions. A parameter set that minimizes transmission error at a single operating point may perform less favorably elsewhere in the operating envelope. The applied workflow combines a coupled-slice contact model, Hertzian contact calculations, and reusable finite-element-derived gear-body compliance. This hybrid formulation enables broader parameter exploration, although its assumptions and validity range must be verified against higher-fidelity calculations and experimental data. Computational efficiency is relevant only if the model resolves the design differences required for the engineering decision.
Gear-Body Architecture as a Structural Design Variable
The web and rim determine local compliance, modal stiffness, inertia distribution, damping utilization and coupling to the shaft. Powder-metallurgical near-net-shape processing enables voids, ribs, curved load paths, and local section variations to be integrated directly into the gear body. These features can be designed to modify both loaded tooth behavior and the structure-borne transmission path through the transmission. Gear-body optimization studies demonstrate the potential of modified and topology-optimized architectures to reduce mass and vibration through targeted redistribution of stiffness and inertia (Refs. 2, 3, 7). This manufacturing capability is a central element of the proposed NVH solution: it allows the gear body to be developed around the characteristic properties of the PM material instead of reproducing conventional wrought-steel geometry. PM-specific investigations further demonstrate that near-net-shape production can be combined with local surface densification to preserve geometric freedom while increasing the load-bearing capability of the tooth surface (Refs. 12, 13). Tooling, compaction, density distribution, ejection, rolling, and subsequent processing therefore define a coupled product-process design space and should be included from the beginning of the optimization.
The description of a design as providing a “longer structure-borne transmission path” may be useful conceptually but does not, by itself, demonstrate attenuation. A curved or interrupted load path changes compliance and modal behavior and may also introduce an undesired resonance. The relevant criterion is whether the modification reduces the response transmitted to the bearings and radiating surfaces under the prescribed excitation. Modal analysis, frequency-response calculations, and structure-borne transmission-path measurements provide stronger evidence than a qualitative representation of the vibration path. Similarly, a pocket or void should not be described as trapping vibration unless the underlying mechanism has been demonstrated experimentally or numerically.
A Campbell diagram relates structural eigenfrequencies to speed-dependent mesh orders. For each candidate design, relevant order crossings should be identified within frequently used torque-speed regions and assessed with respect to modal excitation and coupling to the housing. An increase in natural frequency is not intrinsically beneficial, because it may shift an order crossing into another relevant operating region or toward a different harmonic. The objective of optimization is therefore a favorable system response over the prescribed duty cycle while satisfying strength, mass and manufacturing constraints.
Integrated Use of All PM Design Levers
The transition from wrought steel to PM should be treated as a coordinated redesign rather than as an isolated material substitution. Three design levers must be addressed simultaneously: the PM material and manufacturing route define density, elastic modulus, damping, strength, and geometric freedom; PM-specific microgeometry restores the loaded contact conditions and mesh-excitation level; and the gear-body architecture tailors modal frequencies, structural coupling, and the structure-borne transmission path. If one lever remains optimized for the wrought-steel reference, it can limit or mask the benefit provided by the others. Higher material damping can reduce system response only after the excitation level has been controlled, while a favorable gear-body mode shift remains effective only if the associated order crossings lie outside critical operating regions.
Figure 5 was created using an NVH database based on approximately 300 NVH test results from system-level EDU testing, comprising more than 60,000 data points. It compares the frequency-dependent NVH response of lower-density PM gears with a wrought-steel reference, grouped according to whether the tooth microgeometry was adapted to the PM-specific compliance. Replicate measurements were averaged before comparison, and results are reported as mean noise differences within the indicated mesh-frequency bands. The plotted quantity is ∆dB(A) = PM dB(A) − wrought-steel dB(A); negative values indicate lower noise with PM, while positive values indicate higher noise.
Without PM-specific microgeometry optimization, the mean difference ranges from −0.66 dB(A) in the 0–1 kHz band to +2.11 dB(A) in the 8–9 kHz band, showing that a material substitution alone does not provide a consistent acoustic benefit. With adapted microgeometry, all reported differences are negative. The reductions range from −0.08 dB(A) in the 0–1 kHz band to −7.40 dB(A) in the 9–11 kHz band, with particularly favorable results above 3 kHz.
The comparison indicates that the acoustic potential of the PM configuration is unlocked only when the tooth microgeometry is adapted to its material properties and loaded compliance. However, the two rows represent complete implementation groups rather than controlled same-design pairs, so the observed difference cannot be attributed to microgeometry alone. The results therefore support the integrated design approach: PM material properties, tooth microgeometry, and gear-body architecture must be engineered together to achieve a consistently favorable NVH response across the relevant frequency range.
Development Case: Distinction Between Acoustic Performance and Robustness
The development case followed a staged, PM-centered design approach. Gear-body concepts from a PM-feasible design library were evaluated against the application-specific requirements, including resonance interruption at critical frequencies, mass and stiffness targets, and strength and package constraints, and were refined where required. The tooth microgeometry was subsequently optimized for the PM material properties and the stiffness of the selected gear body, compensating for load-dependent stiffness variations across the relevant operating conditions.
The resulting concepts were then assessed at system level to determine not only their absolute acoustic performance, but also the robustness of their NVH behavior. A concept may achieve the lowest measured noise at selected operating points and still show large scatter, insufficient separation from structural resonances, or a strong dependence on operating conditions. To distinguish between acoustic performance and robustness, the NVH design fingerprint characterizes the intrinsic acoustic behavior of a gear-body concept after operating-point effects such as torque, frequency and mesh order have been removed from the measured data. Instead of relying on a single noise value, it rates each concept against five individual criteria and one composite score that together describe how quiet, stable, predictable, resonance-safe and transferable a design is. Comparisons are only made within the same project and, where relevant, within the same material group.
The five individual criteria and one composite score are defined as follows:
Acoustic performance: Describes the absolute residual noise level of a concept after operating-point effects have been removed. A high score indicates that the gear body itself transmits and radiates less mesh excitation energy.
Frequency stability: Describes how evenly the acoustic response is distributed across the frequency range, without pronounced local spectral peaks. A high score indicates a smooth spectrum, whereas a low score points to distinct tonal peaks that typically require microgeometry or structural refinement.
Repeatability: Describes the scatter of the residual noise level between repeated tests, test conditions, and parts, expressed as residual standard deviation. A high score indicates a predictable NVH behavior that is less sensitive to unit-to-unit variation.
Resonance safety: Describes how far the operating points lie from structural natural frequencies, assessed by the share of points within ±50 Hz of a natural frequency and the mean modal separation. A high score indicates a low risk of dynamic amplification and mode crossing.
Operating independence: Describes the combined sensitivity of the noise level to speed, torque and frequency, expressed in dB per standard deviation. A high score indicates that the acoustic behavior depends only weakly on the operating condition and is therefore more likely to transfer to other applications.
Overall fingerprint: Combines the five individual criteria into one project-normalized score that summarizes the overall NVH quality of a concept. It supports ranking, but it does not replace the individual criteria, which reveal the specific strengths and weaknesses of a design.
Seven physically tested gear-body concepts were evaluated using the NVH design fingerprint. The assessment is based on the aforementioned NVH database. To protect proprietary design information, the concepts are anonymized. Table 1 reports the project-normalized rank of each concept for the five individual criteria and for the overall fingerprint. A rank of 1 represents the most favorable result. Comparisons were performed only within the respective project and, where applicable, within the same material group.
Figure 5—Mean noise difference, PM minus wrought steel, by mesh-frequency band, with and without PM-specific microgeometry. Negative values indicate lower noise with PM.
Concept 1 achieves the highest overall fingerprint rank. It ranks first in acoustic performance, repeatability, and resonance safety, while placing third in operating independence and fourth in frequency stability. This combination indicates a favorable balance between low residual noise, predictable behavior, and limited susceptibility to resonance-related amplification. Its comparatively weaker frequency-stability result nevertheless points to localized spectral variation that may benefit from further microgeometry optimization or structural refinement.
Concepts 2 and 3 share the second-highest overall rank but with different profiles. Concept 2 leads in repeatability, resonance safety, and operating independence, demonstrating robust behavior despite weaker acoustic performance and frequency stability. Concept 3 leads in frequency stability and ranks second in operating independence but performs less favorably in acoustic performance and resonance safety. This contrast highlights the importance of considering the individual criteria alongside the overall fingerprint.
Concepts 4 to 7 show greater trade-offs. Concept 4 combines strong acoustic performance with weaker repeatability and operating independence, while Concept 5 performs well in frequency stability but less favorably in resonance safety and operating independence. Concepts 6 and 7 show predominantly mid-to-lower rankings, with Concept 7 ranking lowest overall.
Based on this assessment, Concept 1 provides the strongest overall basis for further development. The next optimization step should preserve its favorable acoustic performance, repeatability, and resonance safety while improving frequency stability and maintaining low sensitivity to operating conditions. The fingerprint assessment addresses NVH behavior only. Durability, dimensional stability and manufacturing feasibility must therefore be evaluated independently before the concept can be considered suitable for transfer to series production.
Table 1—Project-normalized ranks of seven anonymized gear-body concepts on five NVH criteria and the overall fingerprint (1 = most favorable).
Conclusions
Powder metallurgy can form the technological basis of a low-noise gear solution when its material and manufacturing characteristics are used as coordinated design levers. Material damping provides a mechanism for reducing critical resonance amplitudes, while near-net-shape capability enables the gear-body architecture to be tailored to the required stiffness, inertia distribution and vibration-transfer behavior. Tooth microgeometry can then be adapted to the PM-specific compliance so that mesh excitation and structural response are optimized together. Efficient contact models and simulation-based models expand the accessible design space, and system-level measurements quantify the resulting acoustic performance. With PM-adapted microgeometry, the evaluated configurations show lower mean noise than the wrought-steel reference in every reported frequency band, with differences from −0.08 to −7.40 dB(A). The resulting PM-centered approach combines acoustic level, robustness, mass, durability, and manufacturability within a single engineering framework and provides a practical pathway toward low-noise intermediate gears for electric drive units.
References
  1. Baviskar, S.; Kamble, P.; Ghale, G.; Bendre, P.; Prabhakar, S.; Kunde, S.; Thakur, S.; Wagh, S. “Structural and Micro-Geometry Optimization of an Electric Drive Unit for Whine Noise Reduction.” SAE Technical Paper, No. 2026-26-0315, 2026. DOI: 10.4271/2026-26-0315.
  2. Brimmers, J.; Brecher, C.; Scholzen, P. “Sustainable Gears—Design of Gear Body Modified Powder Metal (PM) Gears.” Gear Technology, October 12, 2022.
  3. Cosco, F.; Adduci, R.; Muzzi, L.; Rezayat, A.; Mundo, D. “Multiobjective Design Optimization of Lightweight Gears.” Machines, Vol. 10, No. 9, Article 779, 2022. DOI: 10.3390/machines10090779.
  4. Gierl-Mayer, C.; Danninger, H. “Physical Properties of Sintered Steels: Effect of Porosity on Young’s Modulus, Damping and Electrical Conductivity.” In: Proceedings of the World PM2022 Congress and Exhibition, Lyon, France, 2022. DOI: 10.59499/WP225377374.
  5. He, S.; Du, I.; Li, B.; Bahk, C.; Grguras, Z.; Baladhandapani, D.; Patruni, P. K. “Optimization of Lightweight Gear Blanks to Improve NVH for an Electric Drive Unit.” SAE Technical Paper, No. 2026-01-0001, 2026. DOI: 10.4271/2026-01-0001.
  6. Im, D.; Chung, W.-J.; Lee, H.; Lee, Y.-J.; Sung, H.; Lee, M.; Park, Y.-J. “Analysis of Gear Transmission Error in Helical Gear Using Enhanced Tooth Contact Analysis Model Considering Measured Tooth Profile Errors.” Scientific Reports, Vol. 15, Article 5981, 2025. DOI: 10.1038/s41598-025-90010-6.
  7. Ramadani, R.; Belsak, A.; Kegl, M.; Predan, J.; Pehan, S. “Topology Optimization Based Design of Lightweight and Low Vibration Gear Bodies.” International Journal of Simulation Modelling, Vol. 17, No. 1, pp. 92–104, 2018.
  8. Ternero, F.; Guerra Rosa, L.; Urban, P.; Montes, J. M.; Cuevas, F. G. “Influence of the Total Porosity on the Properties of Sintered Materials—A Review.” Metals, Vol. 11, No. 5, Article 730, 2021. DOI: 10.3390/met11050730.
  9. Wei, B.-Y.; Li, J.-Q.; Cao, X.-M.; Han, C.-Y. “Calculation of Gear Mesh Stiffness and Loaded Tooth Contact Analysis Based on Ease-Off Surface Topology.” Advances in Mechanical Engineering, Vol. 14, No. 11, 2022. DOI: 10.1177/16878132221133979.
  10. Zhang, L.; Cai, X.; Peng, G.; Hu, J.; Yu, H.; Tang, T. “Optimization and Prediction for Gear Microgeometry Modification Considering Fabrication Errors.” Journal of the Brazilian Society of Mechanical Sciences and Engineering, Vol. 46, Article 48, 2024. DOI: 10.1007/s40430-023-04609-9.
  11. Brecher, C.; Löpenhaus, C.; Schroers, M. G.; Frech, T.; Scholzen, P. A. “Optimization of NVH-Behavior of Gears by Alternative Gear Materials.” In: International Conference on Gears 2017, VDI-Berichte 2294.1, pp. 539–551, 2017. DOI: 10.51202/9783181022948-539.
  12. Klocke, F.; Schröder, T.; Kauffmann, P. “Fundamental Study of Surface Densification of PM Gears by Rolling Using FE Analysis.” Production Engineering, Vol. 1, No. 2, pp. 113–120, 2007. DOI: 10.1007/s11740-007-0006-z.
  13. Kauffmann, P. Walzen pulvermetallurgisch hergestellter Zahnräder. Ergebnisse aus der Produktionstechnik, Vol. 5/2013. Aachen: Apprimus Verlag, 2013. ISBN: 978-3-86359-110-6. URN: urn:nbn:de:hbz:82-opus-44756.
  14. Frech, T.; Scholzen, P. A.; Löpenhaus, C.; Klocke, F. “Powder Metal Gears for Highly Loaded Powertrains: How Powder Metallurgy Supports Current Trends in Transmission Technology.” SAE International Journal of Materials and Manufacturing, Vol. 11, No. 4, pp. 431–440, 2018. DOI: 10.4271/2018-01-0989.
  15. Gaisina, V.; Andersson, M.; Bonvalet-Rolland, M.; Odqvist, J.; Larsson, P.-L.; Gudmundson, P. “On the Mechanical Behavior of Sintered Astaloy-85Mo: Influence of Porosity and Sinter Conditions.” Materials Science and Engineering: A, Vol. 841, Article 143052, 2022. DOI: 10.1016/j.msea.2022.143052.
  16. Hua, X.; Thomas, A.; Shultis, K. “Recent Progress in Battery Electric Vehicle Noise, Vibration, and Harshness.” Science Progress, Vol. 104, No. 1, 2021. DOI: 10.1177/00368504211005224.
  17. Cao, Y.; Wang, D.; Zhao, T.; Liu, X.; Li, C.; Hou, H. “Electric Vehicle Interior Noise Contribution Analysis.” SAE Technical Paper, No. 2016-01-1296, 2016. DOI: 10.4271/2016-01-1296.
