DayLube Extends Maintenance Intervals
New DayLube high performance nano-ceramic grease maintains its original viscosity and adhesion even after 100,000 production strokes – significantly extending service intervals for all types of production equipment. Nano-ceramic particles act as sub-microscopic ball bearings to provide continuous lubrication to steel surfaces. With a much lower coefficient of friction at all temperatures than traditional PTFE greases, chemically inert DayLube is also environmentally friendly. It maintains its viscosity across full temperature range and is NSF-H1 Food Grade Certified. DayLube provides suitable friction reduction and wear resistance for a wide range of industrial applications such as the protection of bearings, bushings cables, cams, chains, conveyors, gears, lifters, machine parts, robotics, slides, wear plates and more. DayLube operates in temperature ranges from -40°F to 800°F– and the nanoceramic particles remain intact to 2500°F. It survived the ASTME 4-ball weld test with no weld and minimal damage to all ball bearings.
DayLube has high load-bearing properties, a low dielectric constant, does not contain metal or silicone and is resistant to steam, acids, and most chemical products. “Customers using DayLube report significantly longer service life – up to 10-times longer – than traditional PTFE lubricants” said Dayton Progress Marketing Communications Manager Brian Marsh. “Even when compared to nanotechnology products, DayLube has a lower cost per ounce. When considering all factors there is not a better lubricating value than DayLube”
DayLube is available in 16-ounce tubes and 16-ounce jars, as well as 1-gallon and 5-gallon pails. Industries benefiting from the use of DayLube include aerospace, agricultural, automotive, can makers, consumer goods, food and beverage processing, general manufacturing, marine, material handling, medical/scientific, military/national defense, pharmaceutical, stamping & fabricating, truck & bus, and more.
