Crouzet Expands BLDC Power Range
A line of high-performance, geared BLDC motors (pictured) is available with a complete tool kit of selectable gearboxes, controllers, brakes and smart drives from Crouzet North America, a company of Custom Sensors and Technologies. The motor's concept allows different configurations to be assembled quickly for fast prototyping while providing a complete automated solution tailored for individual customer needs.
The motor line provides more options for Crouzet's motor offerings. "Crouzet has expanded the continuous power range of the BLDC motors it offers from 30-100 watts to 17-205 watts," says Jim McNamara, Crouzet application engineer. "The gearboxes used in this product are designed for a longer service life than other Crouzet models."
The low-cost BLDC motors feature a wide selection range for power, speed, torque and size. The motors include continuous power up to 400 watts, speeds between 1,500 and 6,100 rpm and motor constants up to 15 ounces per square root watt (103 mNm per square root watt). Maximum torque constants feature up to 198 ounce-inches/amp (1,400 mNm/amp). The six new models include two round and four square designs with lengths ranging from 41 millimeters to 114 millimeters. Motors can be ordered with a factory-mounted optical or magnetic encoder and can be fitted with electromechanical fail safe power-off brakes.
"The power range of 17 to 205 watts is best for small, but not micro applications," McNamara says.
Compatible gearboxes feature spur, planetary and worm styles with torques from 0.4 Nm to 120 Nm. The BDE30 and BDE40 external drives are offered in 6A or 14A max respectively. Internal drives are available on BLDC motors that feature power ranges from 40 to 100 watts. "Accessories include right angle and planetary gearboxes, brakes and encoders, and external drives," McNamara says.
The motor control solution is appropriate for a range of applications in the medical and industrial markets. Uses include automation for endoscopy, x-ray and dental equipment, robotic pool equipment, peristaltic pumps, access control, printing and bill boards. "One customer uses our 80 watt BLDC motor with an integrated controller in a solar powered pump application," McNamara says. "Another customer uses a BLDC motor with a controller for automatic subway doors that provides high acceleration and dynamic braking."
